Afternoon all,
Hoping somebody can shed some light...
I'm running WF4 and have recently upgraded to M110 from M050. With M050 if I selected to replace an assembly component with an unrelated component, I could select the "Edit Ref Table" button and define the replacement assembly features. When I attempt the same thing now, selecting the "Edit Ref Table" button doesn't work... I get a message in the notification area that indicates "Option Pro/ASSEMBLY not ordered, please contact your sales representative".
Has anybody else seen this same behavior with M110? I have also recently received new license codes due to moving the FlexLM server... there were no other license changes, so I can't see how this might have caused this issue.
Thanks in advance for your help.
Ewan
Thanks António and David for your replies.
I don't have AAX, which I believe used to be required for this functionality (via an interchange assembly). As I recall, starting with WF4, this functionality was included with Foundation, and worked perfectly with the builds up to M050 (64bit). I haven't tried any builds between M050 and M110, but it definitely isn't working with M110 (64bit). Interestingly, I received a reply to this posting from another user who reported that this functionality <u>is</u> working with 32 bit M110.
Ewan
Hi Vincent,
Thanks for jumping-in and clarifying this issue… appreciated.
I’ve rolled back to WF4 M050 so I can take advantage of the “bug” for now. I gather when we move to WF5 I’ll need to take a closer look at AAX.
Ewan
Thanks David for posting this workaround... albeit an officially unsanctioned one 😉
Ewan
