Warning Message List
Not applicable
My company just installed Wildfire 4.O and we are getting a warning message list when wildfire is started up. When you press ok it goes away and it lets you work normally. here is the warning message list: Features Obtained: PROE_FoundationAdv Advanced_Assembly_Set Mechanism_Design ModelCHECK Collaboration Features Not Obtained: Advanced_Surface_Set Advanced_Design_set Mechanism_Dynamics Pro/SHEETMETAL Is there anyway to make this go away?
Brian, this comes up when your license configuration is set to upload all those modules alltogether, but if they are already taken by other user (whoever opened up pro/e first), you get the description of which modules could not be uploaded. You can set a new license scheme to upload only the basic modules you use every day, and an advanced setting to upload the rest. This is done throught the flexnet setup enviroment. Now, if you don't have any of these modules (meaning available in your license file), you may want to get a ptc call to work this out. However it is not a seriuos issue, anoying yes, but doesn't get any further.
Not applicable
(To:ClaudioStammitt)
thanks for the comment. I will look at how it was installed and get this fixed. thanks again
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
