helix (3d curve) for a VSS
al204
hello folks,
I need to create a 3d helix curve....how can I do that?
I need to use it as the main curve for a VSS feature.
Later on I plan to use it to create a trajectory milling sequence, that is why I can´t use a helical sweep.
Is there a special function to create this type of features? 3d curves?? Is it using an equaction?
thanks, regards
Create a datum curve by equation. Choose the cylindrical coordinate system
option and pick your coordinate system. In the window that pops up you can
type something like:
r = 5
theta = 360 * t * 16
z = 1 + 23 * t
This will give you a helical curve with radius of 5, 16 full turns and the
curve starting and stopping at z = 1 and 24 respectively.
r, theta and z are required parameters though you can add your own to do
calculations provided you have these three.
t varies from 0 at the start to 1 at the end. The curve is generated
continuously in between.
Mark von Huben
