A little more detail. The attached drawing should make things a little clearer. (Click on the thumbnail, then click on the image again in imageshack to see it clearly.) Also, there seems to be an error in the PTC article; I believe DTM1 should be set at 10 degrees, not 30, according to the values shown in the illustrations. Another thing you can explore if you're interested is creating a
Datum Curve by
Equation. If you do, you will be creating parametric equations which depend on a parameter
t which (like trajpar) varies from 0 to 1 to establish the range of evaluation. If you create such a curve, you will have to copy it with a Sketched Curve to generate additional geometry. Finally, it is a good idea to use the Quilt technique suggested in the article to produce the numerous teeth on your gear. If you create the teeth with solid cuts or protrusions and pattern them, Regeneration will be much slower. David
