simulation for a g-force specification lift
lylebeidler
I have a requirement to do an FEA on a trailer, where the trailer is being
lifted by a crane. The specification calls for a 3-g crane lift (ie, if the
crane lifts the trailer with a force of 3 g's, will the wheels fall of when
it leaves the ground?) I'm not sure how to model the loads and constraints.
Is my best bet to constrain the model at the lift points, and then set a
gravity load of 3 g's? Is this possible?
Thanks.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
That is a pretty standard specification. It means that there is acceleration
on the lift - i.e. the spooling of the lifting cable is not quasi-static. It
also implies a safety factor since the actual acceleration is not known.
I've typically used a constraint (123) at the 'pick point' of the cable and
applied a 3-g acceleration profile. You need to make sure your Mass Center
of what is being lifted is below the pick point if you are to avoid
rigid-body displacement in your simulation. Check your cable loads to make
sure they are always in tension.
Let me know if you need any help with this.
I hope this helps.
Best regards,
Matthew
Matthew Ian Loew
530.797.6055 Voice
908.497.6055 Fax
www.linkedin.com/in/matthewloew
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
