solidifying problem
DarylWolf
solidifying problem
i have an error i don't understand. "Warning; One-sided edge found in SOLIDIFY_4." what is a one sided edge and how do i find and fix it. i have been working on this for hours. any help would be great. thanks ahead. Daryl
8 REPLIES 8
Your surface model is not a closed volume. Any surface quilt you want to solidify must be able to "hold water", but like a balloon, not a simple cup, if that makes sense. Look for a yellow edge, and do eomething to fix it. Can't tell you what since I don't have the model in front of me. Good luck!
DarylWolf
(To:ptc-1181807)
my surfaces are water tight. i pulled the quilt into mastercam and it solidifies at .0005". mastercam can't ever solidify anything so it must be tight. i think there may be a bad surface or something but i have never had that error before that is why i was asking. i thought maybe someone had seen it before and knew what the problem was. thanks for the help. i am still working on it and struggling. i am actually trying to use this quilt to cut away a hollowed out area in a valve body. not sure if that matters that i am not adding a piece or trying to make a stand alone solid. thanks again
Try changing your relative accuracy to .0005 or something smaller than the default .0012. Sometimes that helps.
DarylWolf
(To:ptc-1696366)
thanks for the reply. i'll give that a try.
Hi there if i dont see model, i can't answer but try this way, Copy the surfaces one after another, not in a single click then merge those when u got closed quilt, u can go for solidify as usual Venu
ä¸�能生æˆ�实体,是å›ä¸ºä½çš„组é�¢æ²¡æœ‰å°�é—­.在ç�€è‰²æ˜¾ç¤ºçжæ€�下å�¯ä»¥çœ‹æ¸…没有å°�é—­çš„ä½�ç½®.
ä¸�能生æˆ�实体,是å›ä¸ºä½çš„组é�¢æ²¡æœ‰å°�é—­.在ç�€è‰²æ˜¾ç¤ºçжæ€�下å�¯ä»¥çœ‹æ¸…没有å°�é—­çš„ä½�ç½® I can see few suare boxes.
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
