welding function problem
opavot
Dear All I use the pro-welding application to creat welding fillet between my two parts I have no problem but I can only creat a surface welding and not a solid welding Do you know the way to transform my welding as a "solid part" or where I can find a tutorial for Pro-welding Many thanks Olivier
Looks like you have the weld correctly defined and no there is not a "weld" feature that is completely solid. The only way to make it solid would be to create a new model feature. In the welding module you have lightweight and solid. You have the solid one. It would be nice to have that weld feature solid, but that is how PTC wanted the weld feature. I have been working on the welding stuff over the last week, so I have been quite versed on it. The only weld information I know is in the Pro-E manuals, the pdf ones that are available to download from the support site. Eric
Eric Many thank for explanations . Now I went on the PTC support site , and I don't find the pdf PRO-E manuls , can you give me the path ? Olivier
http://www.ptc.com/appserver/cs/doc/refdoc.jsp?p=browse_results&Product=Pro%2FENGINEER&Release=Wildfire+4.0&DocType=&Role= Look for "help topic collections" its at the bottom of the web page. It is a large zip file of many Pro-E modules. Eric
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
