I believe this is based on the orientation created the ProE creator. If a view is created in ProE specific for your needs, for instance, you can see that view in IsoDraw. In the same respect, if a view is incorrectly created, or the original ProE model is not properly aligned, it will not be aligned in IsoDraw.
