Hi, all…
We will probably make extensive use of XML comments in the DITA topics that we edit in ArborText editor. Does anyone know of a way to hide them? We know how to collapse them, but are wondering if there was a way to completely hide them, including the enclosing tags, and even better, have ArborText remember the hidden state of the comment when you close and reopen a document.
What would serve us just as well would be for ArborText to remember the collapsed state of XML comments like it does with any other element when you close and reopen a document. Version 6.0 does not do that.
Steve
Hi Steve
You can simply use 'set showcomments=off' that you can stick in your ACL file. See the reference below.
Marcin
In Reply to Steve Fogel:
Hi, all…
Steve
