Arbortext is stripping the / from empty elements when I load them, e.g.
<header:metadata-item name="create-date" value="20100920"/"> becomes
<header:metadata-item name="create-date" value="20100920">
so the document isn't even well formed any more. However, Arbortext still gives it a clean bill of health (no completeness errors). Can someone please point me at the setting in Prefs that fixes this - none of my colleagues is having this issue.
Thanks.
Are you by any chance using 5.3 M010? We had the same problem when we tested that particular version, and opened a service call. The problem is resolved in 5.3 M030 and later versions.Meghan Fiero
Thanks.
In Reply to Meghan Fiero:
Yes, I am using 5.3 M010. What a nasty little bug! I will get the latest maintenance release and test to see if it fixes the issue for me too. Thanks for the info!
In Reply to John Hanratty:Are you by any chance using 5.3 M010? We had the same problem when we tested that particular version, and opened a service call. The problem is resolved in 5.3 M030 and later versions.Meghan Fiero
Thanks.
That's why we have maintenance releases J
These email alerts to available updates are quite handy also!
http://www.ptc.com/appserver/cs/subscriptions/subscriptions.jsp?p=tab_summary
Cheers
Chris
