I know that WebLogic 9 has not been certified for ArborText PE, but I was wondering if anyone is using that configuration.
My initial attempt at configuring APE into WebLogic 9 did not work and was wondering if others were able to get it working.
If I try to click on one of the links on the test page, for example, I get the following log message:
"Function 'convert' is not defined"
