COUNTING ELEMENTS
Level 1
COUNTING ELEMENTS
I am looking for a way to count the different tags used in my document.
I am using a slightly modified Navy NAVSEAC2 DTD and am looking to edit the DTD
to remove all the unused tags.
Since I have over 80 documents I want to make sure that I haven't left any out.
Bill Kone
Tags (2)
COUNTING ELEMENTS
I got this function from the Arbortext ACL course last year. I just ran it
to make sure I hadn't "corrupted" it in any of my playing around. From the
command line run "count_tags()" (without the quotes). You'll need to read
past the PI's, but you'll get a list of everything in the instance.
# count_tags
# Description :
# Count all the occurrences of each tag in the current document
# Usage syntax : count_tags()
# Inputs : none
# Returns : List of all tags in the document and how many times
# they occur
function count_tags () {
delete(COUNTS);
caret first,first;
o = oid_first();
while (oid_valid(o)) {
n = oid_name(o);
COUNTS[n]++
o = oid_forward(o);
eval "Number of occurrences of each tag in this document\n\n";
for (n in COUNTS) {
eval "\t $COUNTS[$n] \t $n" output=>*
Lynn E. Hales
Information Systems Specialist
AMSEC LLC
(757)688-9324
hales_le@nns.com
COUNTING ELEMENTS
# count_tags
# Description :
# Inputs : none
# they occur
delete(COUNTS);
caret first,first;
o = oid_first();
n = oid_name(o);
COUNTS[n]++
o = oid_forward(o);
for (n in COUNTS) {
Lynn E. Hales
AMSEC LLC
(757)688-9324
hales_le@nns.com
