I know I can customize the appearance of the default frameset. However, I really need to have a search capability in addition to TOC and Index - like the one in AE Help System. Is that possible without using DMP - I want to use Web output only?
I try to do the same but without any result.
Did you found a way to do this?
No, I did not. I don't think Arbortext comes with the resources to provide search. DMP provided search but WebHelp does not. At least that's my conclusion at this point. So, I am looking at other options.
