Hi everybody,
I'm stuck with this one...
I try create macro to select everything countaining color fill exept for the Black, White, and no fill, and apply to a pre define color called Shaded Area who is a black 45%. If somebody could help with that one it will be much appreciated!
Thanks a lot!!!
Macro Shaded Area
Add color "Shaded Area"
activeDoc.colors["Shaded Area"].kind = "CMYK_color"
activeDoc.colors["Shaded Area"].color.type = "cmykValues"
activeDoc.colors["Shaded Area"].color.CMYK = "{CMYK 0 0 0 0.45}"
Select if Color is not equal to '$ISO_NOFILL'
Subselect if Color is not equal to 'Black'
Subselect if Color is not equal to '$ISO_WHITE'
Color "Shaded Area"
Select none
End Macro
This may not be the best way, but it works
Macro Shaded_Area
Define i as Integer
Define Count as Integer
Define el as Element
Add color "Shaded_Area"
activeDoc.colors["Shaded_Area"].kind = "CMYK_color"
activeDoc.colors["Shaded_Area"].color.type = "cmykValues"
activeDoc.colors["Shaded_Area"].color.CMYK = "{CMYK 0 0 0 0.45}"
Count = activeDoc.selectedElements
el = activeDoc.firstSelectedElement
Define myFill as Fill
myFill.type = "color"
myFill.colSpec.type = "colorRef"
myFill.colSpec.color = "Shaded_Area"
for i = 1 to Count
el.fill = myFill
el = el.nextSelectedElement
End for
Select none
End Macro
I've had a go at it myself, but can't find a way to change the color. When you use record macro, the resulting file is blank when at the bit where you change the color, making me think they've not put in an facility to change fill colours. Hope someone proves me wrong
Macro Shaded_Area
Define i as Integer
for i = 1 to Count
el.fill = myFill
End for
Select none
End Macro
Wow it work so well!!!
Big thanks to you, it is much appreciated!!!!
