Change in PostScript output
ptc-953926
Adepters:
Has anyone noticed that PostScript
output from Arbortext publisher has changed from 5.1M to 5.2? Specifically,
the PostScript that controls the PDF bookmark TOC has been changed and breaks
our downstream processes that fine-tune this area. I checked in the 5.2
release notes and don’t see any mention of this. Did I miss this
somewhere?
Dave
I take it from the overwhelming response that no one has (or
cares about) this PostScript issue?
<span<br/>style='font-size:10.0pt;font-family:Tahoma;font-weight:bold'>From:<font<br/>size=2 face=Tahoma>Sent: Wednesday, September 13,
2006 9:26 AM
To: adepters@arbortext.com
Subject: Change in PostScript
output
<span<br/>style='font-size:12.0pt'>
Adepters:
Specifically, the PostScript that controls the PDF bookmark TOC has been
changed and breaks our downstream processes that fine-tune this area. I
checked in the 5.2 release notes and don't see any mention of this.
Did I miss this somewhere?
Dave
We are currently still stuck on Epic 4.3.1, so we will go
from that to 5.2 or later, so differences between 5.1 and 5.2 should not matter
to us, unless the same differences are noticeable between 4.3.1 and 5.2.
Also, we use Print Composer and not Arbortext Publisher.
I am really not familiar with Arbortext Publisher.
Does it use external printer drivers the way that Print Composer does? If
so, if you changed printer drivers (or your IT support people changedone
without your knowledge), are you sure that the printer driver is not causing
these issues?
Sorry I can't help you more.
Sent: Thursday, September 14, 2006 12:31 PM
To:
Subject: RE: Change in PostScript
output
style="FONT-WEIGHT: bold; FONT-SIZE: 10pt; COLOR: purple; FONT-STYLE: italic; FONT-FAMILY: Arial">I
take it from the overwhelming response that no one has (or cares about) this
PostScript issue?
style="FONT-WEIGHT: bold; FONT-SIZE: 10pt; FONT-FAMILY: Tahoma">From:face=Tahoma size=2>
<st1:personname <br="/>w:st="on">adepters@arbortext.com</st1:personname>
style="FONT-WEIGHT: bold">Subject: Change in PostScript
output
face=Arial color=purple size=2>style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: Arial">Has anyone noticed
that PostScript output from Arbortext publisher has changed from 5.1M to
5.2? Specifically, the PostScript that controls the PDF bookmark TOC has
been changed and breaks our downstream processes that fine-tune this area.
I checked in the 5.2 release notes and don't see any mention of this. Did
face=Arial color=purple size=2>style="FONT-SIZE: 10pt; COLOR: purple; FONT-FAMILY: Arial">Dave
I have a case open about some differences I'm seeing in output between
5.1h and 5.2 m030. I haven't looked at bookmarks yet, though. We are
seeing text kern more widely in 5.2 m030 ... enough to cause different
line breaks. We are seeing some headers defined using regions
formatting higher on the page. Arbortext has said while they don't
guarantee page fidelity between versions, they don't expect any of the
changes I've described.
