Change number in page footers
rkarlík
The setting of change bars in text is OK, but I do not know how to set change numbers (levels) in page footers.
The change number is given in <change> element or 'level' attribute in various elements.
We use Editor/Styler 6.1.
Thank you very much
RichK
rkarlík
(To:TimPhelps)
Thanks, I will try it.
5 REPLIES 5
TimPhelps
(To:rkarlík)
Are you using APP composition, FOSI composition or XSL-FO composition?
Are you wanting the highest level for the document?
rkarlík
(To:TimPhelps)
I use FOSI engine and want the highest level.
TimPhelps
(To:rkarlík)
To output "Change Level #" in the footer, and one has the current change level set in an attribute on the top level element, then you can use
a _ufe: in the text of the page footer region.
Ex. using _ufe:changelevel
The Gentext of the _ufe:changelevel would be
Change Level #<_gte:AttributeContent xpath="/book" attr="role"/>
where "book" is the top level tag and "role" is the attribute containing the change level
Ex. page footer region "page change level"
<_ufe:changelevel></_ufe:changelevel>
Then the appropriate page types would select the page footer region.
rkarlík
(To:TimPhelps)
rdiaz
(To:rkarlík)
Hi Richard,
Any update on this? Hopefully you got it working as desired, but if there are still problems, let the group know. Thanks!
