Changing Frame default in Epic
steve.cuzner
Does anyone know of a way to change the default behavior of Epic so that
table do not have frames? The content model of the frame attribute has a
default value of #IMPLIED and our publishing system treats this as none,
but the edit view treats this as full.
Steve
I don't know what version of Epic you have. We use the fairly-old 4.3.1
version. So there might be some functions to control this in later
versions that aren't in 4.3.1, or that I don't know about (always a
probability). In any case, assuming you use a CALS table and you have
control of your DTD, you can always add a %tbl.table.mdl; entity to your
DTD and change the ATTLIST in its content model from:
frame (top|bottom|topbot|all|sides|none) #IMPLIED
to: frame (top|bottom|topbot|all|sides|none) none
You can still use other values, but it should always default to "none".
Just make sure you declare this in your DTD before you declare your CALS
table.
Steve,
If you don't have control of your DTD/schema, then you might want to look
at the insert_tag_after() callback function, help 148. Have the function
run whenever you insert a table and do a modify attributes to set the
frame attribute to 'none'.
Lynn
