Checking for element content in FOSI
  • July 21, 2010
  • 557 views
I am having some trouble getting my screen FOSI to perform the way I expect it to. I have an element which may or may not have content.
When the element has no content I want to save the word "None" as a text variable and use it elsewhere.
When the element DOES have content I want to save the actual contents as the same text variable name and use it in the same location as the "None".
It works fine when I just save the element content as a text variable and use it elsewhere, except that I get blank content when used elsewhere, instead of the word "None", when there is no content. We would prefer the word "None".
I am trying to use an <att> to test for the existence or non-existence of a value for a the above-described text variable
Let's assume the text variable name is "a.txt". It doesn't seem to matter whether I use <specval attname="a.txt" attloc="#FOSI" attval="#ANY">, <specval attname="a.txt" attloc="#FOSI" attval="#NE#\\"> for the #ANY case
Nor does it seem to matter whether I use <specval attname="a.txt" attloc="#FOSI" attval="#NONE"> or <specval attname="a.txt" attloc="#FOSI" attval="#EQ#\\"> for the #NONE case.
The behavior is inconsistent. If I change it from "#ANY" to "#NE#\\" it will work, but then if I delete the element contents, the text variable value remains the same, as if it still has content.
Similar behavior occurs with the "#NONE" or "#EQ#\\" and adding element content.
I am starting to think that maybe FOSI can't perform this kind of test. Does anybody have any experience with this?
    18-Opal
    July 21, 2010
    Hi Ed-
    I'm not sure if there's a pure FOSI way to do this. But there's an
    example in the online help of how to do it using SYSTEM-FUNC. Check out
    help 1325, in the section "Using the return value of a function as an
    attribute value" (or search for "emptytestfunc").
    --Clay
