<br /><br />In the case of SGML DTDs, the Markit<br />parser is used always. With XML, if you don’t have to compile the<br />DTD, then you’re using Xerces. If your DTD has the version=’1.0’?> PI at the top, the XML doctype will then be<br />required to be compiled and validated using the Markit parser.<br /><br /><br /><br /><br /><br /><br /><br />If your DTD is invalid, you will find out<br />before the document instance can be opened.<br /><br /><br /><br /><br /><br /><br /><br />-Jason<br /><br /><br /><br /><br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /> <br /><br />From: -<br /> <br /><br />Sent: Monday, October 02, 2006<br />4:03 PM<br /><br />To: adepters@arbortext.com<br /><br />Subject: Converting SGML DTDs to<br />XML<br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /><br /><br />Dear Adepter's, <br /><br /><br /><br />I<br />believe that I have just successfully converted one of our SGML DTDs over to<br />XML using Arbortext 5.2. However, is there some type of command that you can<br />issue Arbortext Editor that would return if the document instance along with<br />its governing DTD is for sure XML compliant according to the Xerces parser?<br />This confirmation may be overkill but the reason that I ask is that when I go<br />into Help-->About Arbortext Editor-->Session, there really is no<br />information that tells you if the instance and/or the DTD is XML compliant and<br />what parser has been used to ensure XML compliancy (Xerces or MarkIt). I<br />believe it would be beneficial for Arbortext Editor to tell the user what<br />compliancy (XML or SGML) the document instance falls in under and what parser<br />was used to confirm compliancy? Does anyone else see my point or am I off the<br />mark here? <br /><br /><br /><br />Thanks,<br /><br /><br />Sean<br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br />This is an e-mail from General Dynamics Land Systems. It is for the intended<br />recipient only and may contain confidential and privileged information. No one<br />else may read, print, store, copy, forward or act in reliance on it or its<br />attachments. If you are not the intended recipient, please return this message<br />to the sender and delete the message and any attachments from your computer.<br />Your cooperation is appreciated. >> To unsubscribe from the list, send an<br />email to listmanager@maillist.arbortext.com with the following in the body:<br />unsubscribe adepters - For additional information on the adepters list (how to<br />subscribe or unsubscribe etc), send an email to:<br />listmanager@maillist.arbortext.com with the following in the body: info<br />Adepters - You may also go to forums.arbortext.com, enter the Adepters folder<br />and change your subscription options and preferences.>> <br /><br /><br /><br />
