Create a new document from an XML fragment with ACL
dgopois
With the Arbortext Commands Language , how to create a new document (free-form xml) from an XML fragment. The XML fragment is copied from another file.
In the same way, how to do it using javascript or java?
Kind regards
David
TimPhelps
(To:dgopois)
Is the XML fragment a file entity created by Arbortext Editor, or another fragment type?
If you open the fragment in Arbortext Editor and use from the Command: line
edit -current -untagged
and then
1) Remove the fragment comment
2) Save the document
Does this meet your need?
If so, then it should not be too hard to script this in Java, Javascript or ACL.
Anyone have a suggestion for this issue?
TimPhelps
(To:dgopois)
and then
