<br /><br />You can create SGML/XML help files by<br />creating a separate file with the name of the tag as the filename (e.g. “para.xml”)<br />and placing them in a folder called help within your doctype folder. You<br />can create them using any DTD you like. If there is such a folder with files<br />named this way in your doctype directory, clicking F1 in a document instance<br />will bring up the file associated with that tag in a separate window, or if<br />there is no help for that tag, there will be a message declaring such. So<br />you get context-sensitive help this way. It’s not HTML, but it is<br />fairly useful for not being compiled HTML.<br /><br /><br /><br />This worked for Epic 4.3 and<br />earlier. I am not sure about later versions.<br /><br /><br /><br /><br /><br /><br /><br /> <br /><br /><br /><br /><br /><br /> <br /><br />From: Lofthouse<br />Marsha-PT1816 <br /><br />Sent: Monday, July 24, 2006 2:34<br />PM<br /><br />To: adepters@arbortext.com<br /><br />Subject: Creating Uncompiled<br />Online Help<br /><br /><br /><br /> <br /><br /><br /><br /><br /><br />Noob<br />question: <br /><br /><br /><br />Using<br />Epic Editor, the publishing engine, and a standard DTD/schema (such as DITA),<br />can I product uncompiled HTML-based help? In the information I've been able to<br />locate on the Web, it looks like I'm limited to compiled (.chm) help.<br /><br /><br /><br />Marsha<br /><br /><br />Marsha<br />Lofthouse <br /><br />Motorola, Inc., Public Safety Applications <br /><br />The Americas Group - Content Development<font<br/> size=3 color=black face="Times New Roman"> <br /><br /> Boulder Design Center<br /><br /><br />Marsha.Lofthouse@motorola.com <br /><br />303.527.4178 <br /><br /><br /><br /><br />
