Data merge
ptc-2661555
Data merge
Hi, I'm in the middle of a project where I need to aggregate some data from a MySQL-database into an Arbortext XML-document. I've set up the .dcf and .dmf files needed, and I've read through the samples provided with Arbortext. Still won't work. When I select Insert > Markup > Query, my query defined in the dmf-file won't show up as exptected. The window remains blank, but no errors. Here's the content of my dmf-file:
2287443c8e
Any ideas of what might be wrong? /Johan
Found a few obvious errors, <Label> had to be replaced with <Value>. I see my predefined queries now, but it still won't connect to the database.
anonymous wrote:
Error occured while connecting to data source: [Failed to initialize JDBC driver. Error: [org.gjt.mm.mysql.Driver]. java.sql.SQLException: Failed to initialize JDBC driver.
Moved the .jar file to folder [Arbortext]/custom/classes. Problem solved!
