Hi, we use Epic 5.2 with a custom stylesheet. There are cals-tables in our xml-content, that are renderd by epic. As far as I know, epic has it's own docbook-version and renders such tables with these style-sheets. In our workflow we render the xml to xhtml with our own renderer (based on DocBook, too). Now we noticed a difference between the display in our html compared to the epic view. From my opinion our renderer interprets the xml correctly. But in the epic-view the cals-table is not displayed in same way. There are missing some vertical column lines ... Unfortunately I can't add a picture or an attachment to this topic as an example, but is it possible, that the docbook-stylesheets in epic are old ones ? What can I do to solve this problem ? Thanks Markus
