Hi, I'm trying to find out how to show drop-down lists to document authors in Arbortext Editor (5.2) for elements that allow a limited set of values. I've not been able to find info on this in the editor's documentation, or on this forum. E.g. if elements (not attributes) like status, department, etc are defined in the xsd as restrictions/enumerations, I'd like to create a Styler style sheet that prevents users from freely typing a value but instead lets them select from a list. If this is not possible with a style sheet, is using embedded XUI dialogs a feasible option? Also if the document contains many of such elements? Thanks in advance for any info/ideas you can provide! Gidi
