I have problem when i use ID/REFID
<!-- XML File -->
<table id="tbl-4">
</table>
<para> cccccccccccccccccccccccccc
<obj refid="tbl-4">vvvvvvvvv</obj>
</para>
<!-- TREAT ID -->
<e-i-c gi="table">
<charlist inherit="1" charsubsetref="espvtitre">
<indent inherit="0" leftind="@" firstln="*">
<quadding quad="center">
<textbrk endln="0">
<enumerat increm="1" enumid="tabct">
<savetext textid="tabctxt" conrule="tabct">
<savetext textid="tabnum" conrule="tabctxt">
<usetext source="\Table \,tabnum,\ \" placemnt="before">
<subchars>
<font inherit="1" weight="bold">
<highlt inherit="0" fontclr="blue"></subchars>
</usetext>
</charlist>
<att><fillval attname="id" fillcat="savetext" attloc="table" fillchar="conrule">
<charsubset>
<savetext textid="idtab"></charsubset>
</att>
<att><fillval attname="id" fillcat="savetext" attloc="table" fillchar="textid">
<charsubset>
<savetext conrule="tabnum">
</charsubset>
</att>
</e-i-c>
<!-- TREAT REFID -->
<e-i-c gi="obj">
<charlist inherit="1" ></charlist>
<att><fillval attname="refid" fillcat="savetext" fillchar="conrule">
<charsubset>
<font inherit="1">
<savetext textid="idstr">
<usetext source="\(\,idstr,\ ) \">
<subchars charsubsetref="stdgentext">
<font weight="medium">
<highlt scoring="1" scorespc="1">
</subchars>
</usetext>
</charsubset>
</att>
</e-i-c>
When i applic FOSI to XML file i obtain :
[A28068] Fosi compile failed using default formating information
Use show ids command to locate this error
When i choice show ids : NO errors
Thank you for Help
Hi Bruno,
Did you ever get this solved?
This successfully saves the id to a savetext textid:
<charsubset>
</charsubset>
</att>
Now the stylesheet has a textid=tbl-4.
The approach taken wants this for refid:
<att><fillval attname="refid" fillcat="usetext" fillchar="source">
<charsubset>
<usetext></usetext>
</charsubset>
</att>
That will give you <usetext source="tbl-4">.
If you need to change the output to wrap the cross reference with parentheses, perhaps you can change the original savetext:
<charsubset>
<savetext conrule="\(\,tabnum,\)\">
</charsubset>
</att>
You have to do a straight fillval into a usetext source without any alterations.
I don't think FOSI technology allows you to fillval an id into a conrule. If you need to do something like that you have to use
<savetext textid="idtab" conrule="#CONTENT(id)">
I would question the need for this but I don't know your output requirements.
Jerry Tippie
