Hi Trevor, you could try this approach:
Lock the layers and examine one by one individually (unlock this one before and lock it again afterwards) Use "Select if type is text" (can be recorded) on this layer Examine each selected item (if there are some) by looping through them ("firstSelectedElement ","nextselectedElement")
That should also work within groups. regards, Christian
