Embedding Flash as an Embedded XUI Control in Arbortext
ptc-1894556
Hi - we would like to embed Flash content in a .swf file into an Arbortext xml document.
I see that XUI controls can be embedded into an Arbortext document and that an XUI control can be an ActiveX container (and Flash is ActiveX) so in theory it should all work..
I'm wondering - has anyone ever tried this and if so any details on how it was implemented (or pitfalls) would be great..
thx
David
16 REPLIES 16
Well, as you said, there's an ActiveX component to embed .swf files. You just have to define an ActiveXControl in your .dcf file whith programId=Shockwaveflash.Shockwaveflash.9 (or any other version), inPlaceActivate=yes if you want to have it embeded onto the surface of your document.
You need to have a script to control your Flash movie (at least initialization). You can define 3 functions to do it : controlName_OnInitialize, controlName_OnClose and controlName_OnCancel (see customizer's guide for further informations). Typically, you will have in your controlName_OnInitialize function something like :
controlName.Movie = "your_file.swf";
controlName.Loop = false;
controlName.Play();
It's possible to establish communication beetween Arbortext and your Flash movie, if you need to do it, I should be able to give you some tips about it.
Samuel
Samuel - thanks for your invaluable help..
We are new to scripting in Arbortext .. can you advise where to place the script to control the Flash .swf? Do you have a sample of a very basic flash control script?
(I am assuming you are meaning a javascript script - right?)
We will definitely also need to communicate between Arbortext and Flash so if you can provide details on the tips you mentioned that will be great and save us a lot of time trying to get this to work 🙂
David
David,
Here is a basic script file to load a Flash movie :
File Test.js
Samuel - thanks again for this very helpful info.
We are presently temporarily assigning one of our Flash specialists to the Arbortext project. I will have her try out your code.
Thanks again.
David
Hi Samuel,
I am the Flash person that David talked about in last thread of this post. We really appreciate your help so far .
We tried to make a simple example with your instructions, but didn't succeed. It seems that Arbortext was able to recognize the element name and relate the Flash ActiveXControl to it. Because when I right click on it, it says "About Adobe Flash 9". But the Flash movie wasn't loaded. The same right click menu says, "Movie not loaded". And it displayed a blank on Arbortext. It seems like that the Flash movie wasn't found. I placed a simple flash movie, test.swf, in the same folder as the xml and dcf file.
I attached a zip file. I put it under the folder of "C:\Program Files\Arbortext\Editor\custom\doctypes\flash-test". There is a script file, test.js, which was placed under"C:\Program Files\Arbortext\Editor\custom\scripts" as you suggested. Inside the test.js, it is
* Initialization
function FlashTest_OnInitialize(ActiveNode) {
FlashTest.Movie = "test.swf";
FlashTest.Loop = false;
FlashTest.Play();
The example is really simple with only one xml element. I couldn't figure out what else is missing to just display the Flash movie inside Arbortest Editor.
That would be great if you can try this example and give us some hints. We are stuck. Again, we really appreciate it.
Jin
In Reply to:
David,
File Test.js
Maybe it's a path problem. I currently use absolutes pathnames, and I didn't yet try with relatives.
Hi Samuel, Thanks for your quick reply.
I tried absolute path name as well. For example,
* Initialization
FlashTest.Movie = "C:\test.swf";
FlashTest.Play();
or FlashTest.Movie = "C:\Program Files\Arbortext\Editor\custom\doctypes\flash-test\test.swf";
Is that how you define absolute file path for swf file? Thanks so much.
I finally got it loaded. You are right about file path.
I found that "C:/test.swf" will work, instead of "C:\test.swf".
Thanks.
You may find you need to escape backslashes in quoted strings, eg.
"c:\\test.swf" instead of "c:\test.swf".
-G
Hi Samuel,
I got a new question. Do you know how to embed FlashVars in Arbortext? I assume it is also in the OnInitialize function. But what's the format? I didn't find any information on embedding Flash with Arbortext online at all. Your help is really valuable.
Also can I define the width and height and ScaleMode within OnInitialize function in the way below? I generally want to know how to write embed/param tag that we usually do in a html page.
* Initialization
FlashTest.Movie = "C:/test.swf";
FlashTest.Height = 500;
FlashTest.Width = 800;
FlashTest.ScaleMode = "ShowAll";
FlashTest.Play();
But it didn't work. Maybe I am missing something again.
Jin
Thanks, the escape backslashes worked. Do you know how to define FlashVars for Flash Movie inside ArborText? I assume it should be in the function of ControlName_OnInitialize. But what's the format? I couldn't find any information on embedding Flash inside ArborText in the help documents or online. Your help will be really valuable.
Generally I want to know how to define variables(ScaleMode, Height, Width, etc.) in embed/param tag that we usually do for a html page, is it something like,
* Initialization
FlashTest.Movie = "C:/javadev/FlashTeam/QNATools/test.swf";
FlashTest.ScaleMode= "ShowAll";
FlashTest.Play();
But it didn't seem to be working.
Jin
* Initialization
FlashTest.Play();
Jin
Thanks, the escape backslashes worked. Do you know how to define FlashVars to Flash Movie inside ArborText? I assume it should be in the function of ControlName_OnInitialize. But what's the format? I couldn't find any information on embedding Flash inside ArborText on the help documents or online. Your help will be really valuable.
* Initialization
FlashTest.Play();
Jin
Sorry that I didn't see the second page for this thread. I was wondering what my post went, So I kept trying until I see there is another page. Sorry for the repeat posts.
That's OK, I thought they were from PTC's "Department of Redundancy
Department".
Hi Samuel,
I was reading this thread and wonder if I can Integrate Flash with Java in Epic instead of ActiveX?
-David
