Epic 5.2 Modify Attributes Dialog question
eloise.currie
In the Modify Attributes dialog, if an attribute value is deleted without using the Delete button or Delete All button, the attribute remains with an empty value in the xml when I press OK. I was thinking that using the backspace key, delete key, etc. was enough to delete attribute. I would like to customize the code to call the "Delete" callback on the Modify Attributes dialog when an empty CDATA attribute is detected, but I cannot find the callback; probably because it is buried in a DLL. Where is the source code for the Modify Attributes dialog? Is there another way to solve this problem?
0 REPLIES 0
