Feeding Arbortext XSL-FO documents
ptc-2059836
I'd like to get confirmation if the method I used to submit an already existing XSL-FO document to Arbortext Publishing Engine (APE) is valid: * I created a new custom doctype application that only contains the identity XSLT transform, with the goal of passing the FO markup as-is to the print/PDF/Postscript engine. The DTD I created just references (via parameter entity) the xsl-fo DTD included in the Arbortext distribution. * In my XSL-FO document, I include the doctype declaration that maps to my custom doctype application. * When invoking APE, I select PDF/Postscript output to get final rendered document. The primary goal is to have the simple ability to play with XSL-FO directly and test it against APE. The process seems to work (I do get output), but I need to know that I can trust that the output reflects the original FO I provided w/o it getting modified internally before the print/PDF/Postscript part is called. Thanks for any replies.
lfraley
6-Contributor
(To:ptc-2059836)
Earl,
You should post this question to the Adepters mailing list. Paul Grosso, who works for Arbortext/PTC, and who sits on the FO W3C committee will be able to provide details to you. He watches the list.
You can find the list here:
The List Email Address is: -
You can join the list from the PTC/User portal: http://portal.ptcuser.org/p/fo/si/topic=21
