I found a great thread here on scripting making a flat file which I plan to use to back up the doc as it grows to 3000 chapters - yesterday two of those chapters emptied themselves at 10:05 am - declarations at the top and dozens of pages just gone.
My Question:
I've created a simple instance.acl but can't get it to load and need help on where to put it:
message "production/instance.acl found and read";
if (! menu_exists ("BAE")) {
menu_add -menu .Help "BAE";
menu_add .BAE. "Flatten This Doc" -cmd {flatten_this_doc();};
menu_add .BAE. " -separator;
menu_add .BAE. "Rewrite Entity Declarations" -cmd {set writeentdecls=roottreerefchildnone; save_all_docs;};
It is in \custom\doctypes\production\instance.acl. I also tried \custom\doctypes\production.acl with the same results.
Our doctype declaration:
I've read your posts and the ACL Guide and understand where to put it, but not what to name the directory I guess. I've tried /xml/ and no luck. The PE itself uses /custom/doctypes/Production so I tried that.
flatten_this_doc(); is located in my custom\init\johnsstuff.acl and it loads great...but you can't adjust menus there as they haven't loaded yet.
Sorry to ask such an idiot question...the menu commands work great cut-and-paste into the command line...just can't automate it.
John T. Jarrett
Sr. Tech Writer, BAE Systems
Arbortext version 5.4
LOGSA XSL-FO v 1.5
Beautiful! Thanks for the explanations. And, yes, our DTD is on the server, not our local machines, so that explains why it couldn't find it in doctypes.
I put init.acl in /custom/init/ and yourmenu.acl and yourcommands.acl in /custom/script/ and it works beautifully.
Now off to learn more about hooks.
Thanks VERY much, Alessio!
John T. Jarrett
LOGSA XSL-FO v 1.5
