Forcing use of macros
thendricks
3-Visitor
I have created a custom Save macro for use in our group. It allows a user to save the iso they are working on to a master folder, outputs necessary eps files, and then again saves the iso to the user's working location. My problem falls more into the preference realm but might be in this forums knowledge base. Is there a way to do one of the following? 1) Remove "Save" from the menu. 2) Cause macro to run when "Save" is selected from the menu.
Hi Trevor, the scenario that you described is not possible. Regards, Christian
