Need instructions on converting FrameMaker files into Epic Editor. Or link to instructions would work, too.
Arbortext themselves have a tool to achieve that, it's called Arbortext Import/Export and it can take MIF files as input.
Are you using unstructured FM? If so, the conversion is to a structured format (XML) so that will mean quite a lot of work in setting up the conversion maptemplate and also lots of QA for each file. Some organisations choose to use an offshore conversion vendor if they have a large enough volume of conversion work.
You will need an import/export license.
If you have only a handful of documents and/or only a couple thousand pages, consider using cheap labor to do a copy/paste conversion.
You should also join and ask the Adepters mailing list where lots and lots of Arbortext users, admins, and developers hang out 24/7/366 (it is a leap year, you know!). Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
http://blog.single-sourcing.com/top-arbortext-resources
See also:
Really good summary Paul!
A little on topic, a little off topic, slightly rhetorical - why do these software companies make it so difficult? Isn't the utility of using XML that it can (should) be easily shared between users (software/ hardware/ vendors/ suppliers/ customers...). I guess XML is universal, but the software code to make it pretty is not. ugh
Like any technology I think it is evolving. I'm pretty sure the first cars weren't cheap, reliable and easy to operate... ![]()
