Graphic Problem When Outputting from Print Preview Window
SarahPrice
7-Bedrock
I am in the process of testing 5.3 M090 against our current doctypes and have run into an interesting problem.I have severalpagesets thathavegraphics in the header and/or footer. When performing a print preview everything looks great but when I output from the print preview window, either to a printer or generating a PDF file,I get a reduced version of the graphic in the upper left hand corner of the first page only.
This only occurs when outputting from the Print Preview window. If I use Compose to PDF or just print without a preview it all works fine.
Has anyone run into this problem? If so can you point me in the right direction fix it. I have attached a sample of the file.
Sarah Copley
0 REPLIES 0
