How add a keyboard shortcut to Edit > Profiles > Apply Profiles ?
sfogel
Hi, all...
I'm trying to add a keyboard shortcut to the menu choice Edit > Profiles > Apply Profiles.
I'm aware of the map command, but don't see an ACL command for Apply Profiles that I can map a shortcut for.
Is there some way to do this?
Thx
Steve
HYPERLINK " \nOracle
Steve Fogel | Information Architect, Oracle Database| 650.506.4914
Oracle Server Technologies Information Development
500 Oracle Parkway | M/S 4op1126 | Redwood Shores, CA 94065
On the command line type:
response(menu_cmd("Edit.Profiles.Apply Profiles"))
This should display the name of the command called.
I will bet that it's "ApplyProfiles". They are often that transparent.
sfogel
(To:sfogel)
Thanks, that helped. The command was UpdateElementProfile.
