I'm having trouble creating file entities on my abortext editor 6.0. When I want to create a new entity it says that I have an incorrect entity name. What does that mean? Which public id do I have to choose? Btw I'm using docbook.
Have you reviewed the Arbortext Editor's Help Center topic "File Entities Dialog Box"?
See the difference between "Name" and "File Name"
Has this question been answered?
If so, could you select a Correct Answer, so that the community knows that there was a resolution.
If users can mark threads with the "Correct Answer" then this will help the community identify which threads are most valuable and worth the time to review.
