Hi, for the PTC Arbortext Editor software, is it possible to disable splash-screen at startup ?
Hi, thanks for you response. I would like Arbortext Editor load faster.
Not that I'm aware of, and even if you did it wouldn't make it load faster (I assume that's what you're asking).
