Hello all! I'm Khai, I'm new in using EPIC Editor. I have to display a table which has the element "ENTRY" with the different "align" attribute with EPIC. But I can't insert a Table. I'm trying to change the *.acl files but it doesn't work. I think that I have to write the code to check if a Table is matched with the standard of Epic.But I don't find where EPIC check this. How can I do this without changing the DTD? Thanks very much! Khai
