How to modify the context menu in Arbortext Editor
  • June 23, 2015
  • 1190 views
With ACL language, how to modify the context menu in Arbortext Editor (right click with the mouse)?
Best answer by ClayHelberg
Hi David--
You can use the menu_add command to do this. The menu to modify is ":EditPopup". For example, to add a "Ping" menu item to the context menu, you would use something like this:
menu_add :EditPopup. "Ping" -cmd { response("PING!"); }
--Clay
18-Opal
June 23, 2015
Hi David--
--Clay
dgopois13-AquamarineAuthor
Hi Clay
Thanks for your help.
