Image Element Align Attribute Problem
JonMarcum
Since upgrading to Arbortext 5.4 from 5.3, the "align" attribute for "image" elements seems to not work anymore. No matter what I use for the "align" attribute (left,center,right) along with the "placement" attribute set to "break", it has no effect when I publish to PDF. The image is always aligning the left side of the "figure" element frame when I want it to align to the center. FYI, I am using the Service Manual Application. This worked perfectly in Arbortext 5.3.
lfraley
6-Contributor
(To:JonMarcum)
This sounds like either a bug in the stylesheet or a behavior that wasn't intended that you managed to take advantage of. Graphic alignment is controlled by the stylesheet. Sounds like you need to debug the SMA stylesheet or report the issue to Support.
