Just wondering is anyone has a workaround for 5.4.
If I force a page break in a table in Editor, by Table Properties, Row,
and under Composed Output Option choose Force,
sometimes the title float appears on the following pages of the table (desired behavior)
and sometimes it doesn't. Normal float behavior resumes with following table (assuming no forced page breaks).
PTC said this doesn't occur in 6.0, they didn't have a workaround, and that 5.4 is being "sunsetted" in October.
I had deepcontentsplitting on, so I tried turning it off via the command line and the Continued titles reappeared after the forced page break! Then I turned deepcontentsplitting back on and the Continued titles remained (desired behavior). So far every table I tested works.
Never mind, I restarted AE and now it's not working.
deepcontentsplitting definitely has to be off for it to work. That was the only thing that worked consistently. I put
set deepcontentsplitting=off in an acl file in the pe init folder, but when I opened AE the preference still said on. I thought if you typed a command in the command line it changed the preferences, but I had to change it to "off" manually.
How does one get an acl file to load automatically at project or doctype startup, if you don't want to put it in the pe init folder?
Thanks Ed and Paul!
Ed, did you mean pubrc.acl?
At least one of my mistakes was putting the .acl file in the pe server custom/init folder, instead of the client's.
