Insert Tag UI
berard
Insert Tag UI
Hopefully this will be a simple question...
Does anyone know offhand what causes the quick tag insert to become
available? In our old DTDs with pretty complex FOSIs, hitting the <enter>
key brings up any context-specific tags.
I have created a few new DTDs, but can only seem to get tags inserted by
going to Insert -> Markup then selecting the tag. The DTD itself is
being recognized, and only appropriate tags are available in context.
Furthermore, in Tools->Preferences->Edit, I do have "Show quick tags on
enter" selected.
I created a very very simple FOSI (by hand) to ensure tags are indented
with line breaks, and a very simple DCF to handle hidden tags and restrict
character substitution. This is also in Arbortext 6.0M030.
I can attach any related documents if needed.
keith
10 REPLIES 10
Hi Keith--
Do you have any customizations that change the key mapping for the enter
key? In the OOTB setup, the enter key is mapped to the alias "Enter",
which (after some checking for hooks and stuff) triggers QuickTags.
Double-check to make sure you haven't remapped the Enter key, or
realiased the Enter command. (You can verify this using "show
fullkeymap" and "show aliases".)
--Clay
Clay Helberg
Senior Consultant
TerraXML
berard
(To:berard)
Interesting.
All of our doctypes use the same init acl, so I'm not trying to remap
anything.
That said, "show fullkeymap" shows the following:
* Enter Enter
* KeyPad_Enter QuickTags
That's especially strange, since both keys behave in the same way by
putting in a CR (little hook arrow) rather than ignoring the character and
showing the quicktags list.
"show aliases" lists the following:
Enter {
if (hook_call("enterKeyHook", 0) != -1) {
if (columnview_cell_focus() > 0 ) {
LineDown;
} else if (option("quicktags") == "on") {
QuickTags;
} else {
if (_list::caret_within_list() && _list::split_list_item() == -1 ) {
return;
newline;
QuickTags _return::next_logical_return()
Oh, you get the little linefeed symbol inserted in the text? That
probably means you have the element(s) configured to preserve whitespace
in your doctype, maybe using the xml:space="preserve" attribute. In that
case, Arbortext thinks you want newlines to be newlines, so it lets you
type them with the Enter key.
If that's true, you'll have to decide between preserving whitespace or
getting QuickTags to work in the usual way. You could also write your
own code for the Enter alias that handles the Enter key however you
want.
--Clay
Clay Helberg
Senior Consultant
TerraXML
berard
(To:berard)
Oh, no... we definitely don't want any whitespace preserved.
I had to "dumb down" my reference FOSI/DTD, but here are the relevant
entries:
DTD:
FOSI:
<e-i-c gi="para">
<charlist inherit="1">
<indent leftind="@+5pt" firstln="*">
<quadding quad="asis">
<textbrk startln="1" endln="1"></charlist>
</e-i-c>
Now, my reference FOSI says:
<e-i-c gi="para">
<charlist inherit="1" charsubsetref="block"></charlist>
</e-i-c>
Neither seem to have any effect.
I must be missing something very fundamental here...
Did you verify in your doctype/schema that you don't have
berard
(To:berard)
No schema, just a simple DTD. Not even sure where I would set that in the
DTD.
Just seems that it should be the default, but there's probably something
lurking in our "big" FOSI that I don't know about.
You might be able to use the oid_asis() function to check whether your
elements are set up to display as-is (with newlines). If so, then it
probably is a setting in the FOSI, which I guess you'd have to track
down by going through the FOSI to find the source of the setting.
Clay Helberg
Senior Consultant
TerraXML
berard
(To:berard)
Thanks Clay, I guess my simple approach of "hack together a simple FOSI to
get it to do something semi-usable" will require a bit more thought. I
cringe each time I need to go into ACL to make changes (most of our code is
now in Java), but I double-cringe when it comes to FOSI.
I'll be sure to post the "ah ha!" once I find the culprit.
bibach
(To:berard)
I the the culprit is the '<quadding quad="asis">', which the FOSI help
describes as meaning "exactly as in the source (spaces and line breaks
preserved)".
-Brandon 🙂
berard
(To:berard)
OK, with a little help from PTC support, it was indeed a very simple fix.
According to PTC, as of 5.4, the default setting in the FOSI is to set
<quadding quad="asis">, which also explains why we weren't seeing it prior
to 6.0, as we migrated directly from 5.3. A quick change to the FOSI took
care of it.
Thanks again for the suggestions.
keith
On Mon, Apr 23, 2012 at 4:05 PM, Brandon Ibach <
> preserved)".
> -Brandon 🙂
