Is it possible to call the MarkIt parser from the Windows command line?
ptc-1123085
We are working with documents that need to be parsed against a different production SGML parser, but the editors use Arbortext. We're trying to pin down what is causing 'epic: segment violation (signal 11)' crashes and would like to be able to test documents directly against the MarkIt parser without opening the Arbortext application.
Thank you in advance for any help.
- karen dL.
0 REPLIES 0
