Is it possible to encrypt the ACL code or is there a solution to prevent users to read or modify the ACL code ?
David
Hi David--
I don't know of a way to do this. You might be better off taking an AOM/Java approach, maybe using an obfuscation tool to make your Java classes harder to reverse engineer.
--Clay
Hi David--
--Clay
Hi Clay,
Thank you for your help.
David
