please can some one help.
I need to select text and change the character fill to
rbg 255
rbg 116
rbg 66
I have started with........but the color bit confuses me
macro Change_Text_Color
Select if Type is equal to "Text"
Define el as Element
el = activeDoc.firstSelectedElement
while (Exists (el) = true )
el.fill.colSpec.rgb.green = 255
el.fill.colSpec.rgb.green = 116
el.fill.colSpec.rgb.blue = 66
el = el.nextSelectedElement
end while
end macro
See if this works for you
Macro Text Color
Define i as Integer
Define tCount as Integer
Select if Type is equal to 'text'
tCount = activeDoc.selectedElements
define Mycolor as ColorSpec
Mycolor.type = "rgbValues"
Mycolor.rgb.red = 255
Mycolor.rgb.green = 116
Mycolor.rgb.blue = 66
for i = 1 to tCount
el.fill = Mycolor
End for
Select none
End Macro
Macro Text Color
Define i as Integer
for i = 1 to tCount
el.fill = Mycolor
End for
Select none
End Macro
Many thanks
really saved me >a lot< of time
regards
