IsoView: Which event generated first when clicking the mouse
ptc-2666307
IsoView as an activeX control in Internet Explorer. When I click one hotspot, I want to get the coordination (X, Y) so that I can show a popup menu nearby. I used MouseDown event to get the x and y. However the x and y are used in ObjectHit event handler. I tried several times. Sometimes MouseDown occurs before ObjectHit, which is good, And sometimes MouseDown occurs after ObjectHit, in which case I cannot get the x and y for the ObjectHit event handler. Can somebody here help me? Which event will be generated first when you click the mouse? Thank you in advance.
0 REPLIES 0
