Isodraw v7 Dimension Bar
ptc-1201602
Hello, Has anyone come across this problem when drawing a rectangle and having the X & Y vaues transposed. The attachment shows a rectangle of 240length x 50height but the dimension bar shows these the other way round? This happens on 2 of our terminals (using Isodraw v7 m050)but is ok on the 3rd (using v7 m030)for some reason? Am i missing something in the settings?
Hi Russell, the situation that the values are the other way around as expected happens in the plane view only and can not be changed. It depends how you drag a rectangle when creating it. regards, Christian
