Refer to CASE 11850699.
We have a software security vulnerability with JAVA. We are running 6.0 M080. Since we cannot use the environment variable JAVA_HOME to redirect Arbortext to use the current version of JAVA, we will have to upgrade.
Is there a way to update the HELP feature to use the current version of JAVA? Can the software be modified in the future to use the JAVA_HOME to use the latest version of JAVA?
