I am not sure what is going on with my install in 5.3M030. Everything seems to install ok without errors, but when I open the editor I get the error that it can't find the java runtime environment.
I uninstalled Arbortext, then reinstalled it. I did the same for java.
What am I over looking?
Ellen
Hey Suresh, and any other folks who have this problem and are upset with Ellen.... I kept trying things out until I found it. Control Panel, java , java tab of java control panel , View... button. Then find, and search your C drive. This will inform Java, that it in fact has Java, so that when ArborText tries to find Java, Java doesn't say "never heard of it"
Then it worked.
Hi Suresh,
Sorry I forgot to get back to you. I have looked back through my notes and I haven't come across anything that told me what I did. The only thing Isort of remember isusing the Java Console (Control Panel) I think I needed to change the Java Runtime Environment Settings. I am not sure what I changed there.
Sorry I am not much help. I am sure it was one of those things that I just kept trying things until it worked and wasn't sure what the last thing I had done!
Ellen
