Hey, Randy...
We're not using Documentum on this side of the parking lot, but I may be
able to help you resolve this, anyway. Are you using a custom schema,
or is it one you were provided with? If so, which one? Most
importantly, can you post the declarations for your Graphic element, so
we can see how the attributes are defined? Here comes my Documentum
ignorance. What do these DRL entries look like, and how do you use them
in your documents, now?
If the answers to those questions don't clear things up, I can try to
stop over there and take a look, if that'd be okay. (Much easier to
sort things out in person, generally.)
Brandon Ibach
Lockheed Martin Space Systems
Cape Canaveral, FL
321-476-7051
