Mapping toolbar buttons
jbaklayan
I am using version 5.3. I want to remap a toolbar button to a custom function. In the help, it states I can map a toobar item (such as Toolbar_Print) in Unix only. How do I accomplish the same thing in Windows? Thanks in advance.
5 REPLIES 5
Hi John--
You will need to know the alias called by the button you're interested
in, and then you can "hijack" it by redefining that alias to execute
your own code instead of the stock code. For example, let's say you want
to hijack the File Open button. If you look at the contents of
$ARBORTEXT/lib/dialogs/editwindow.xml, you will find this inside:
<toolbar id="toolbar1" name="&amp;ToolbarEdit;" x="0" y="0">
<button command="FileOpen" id="Toolbar_Open" image="imageOpen"&lt;br"/>
statustext="&EditWindow_StatusTextOpen;"
tiptext="&EditWindow_TooltipOpen;"></button>
The command attribute is the thing you're interested in. To change what
this does, you can use the alias command in your startup ACL file to
make it do what you want, instead of what it does out of the box. For
example:
alias FileOpen { response("This is my custom version of
file open"); }
Note that using this approach will also change the function of
corresponding menu items. In this example, it will change not only the
toolbar button behavior, but also the behavior of the File->Open menu
item.
If you want to only affect the toolbar button, but leave the
corresponding menu item alone, you will probably need to use
dlgitem_set() to specify your code as the callback for the item,
something like this:
dlgitem_set(current_window(),"Toolbar_Open","callbacks","mypkg::myOpen")
where mypkg::myOpen() is a function you have defined to do what you
want, and the dlgitem_set() call appears in your editinit ACL.
--Clay
Clay Helberg
Senior Consultant
TerraXML
1380 Forest Park Circle, Suite 100
Lafayette, CO 80027
A qualification: this is based on version 6.0, there may be (hopefully)
minor modifications needed for 5.3. (Sorry, I don't have 5.3 installed
to test against.)
--Clay
Clay Helberg
Senior Consultant
TerraXML
Lafayette, CO 80027
Thanks Clay that worked. On a side note, is there a way to create a custom toolbar item and define your own function. Currently I am having to "steal" a toolbar function from another item I am not using and redefining it. Ideally I would like to do the following:
<button command="ACLCustomFunction" id="Toolbar_NewItem" image="imageNewItem"&lt;br"/>statustext="New Item"
tiptext="New Item"></button>
If I try and do the above it doesn't know about ACLCustomFunction.
Thanks again.
Hi John--
The normal way to do this would be to make a custom copy of
editwindow.xml, place it in $APTCUSTOM/dialogs, and make your changes
there.
If you add your sample code, it should work OK, as long as you do define
a function called ACLCustomFunction(). Note that you will need to make
sure the function is defined before the window loads, i.e. in your init
ACL file.
Note that you'll also need to define the image for the new button at the
top of the editwindow.xml file in the <imagegroup> section. The default
button images are defined as regions within one big graphic file via
<imagelist>. To add an extra one that's separate, use something like
Hi John,
If you go the $APTCUSTOM/dialogs/editwindow.xml route, not only can you remap toolbar buttons you can add your own custom toolbars by adding new <imagelist> and <toolbar> elements to editwindow.xml.
Create and reference the custom image file and buttons in the new <imagelist> element:
<imagelist path="ToolbarMyCustom.bmp" imagewidth="16">
<image id="imageCustom1"/>
<image id="imageCustom2"/>
</imagelist>
BTW, imagewidth can be larger than 16 for large buttons.
Create and reference the custom command buttons in the new <toolbar> element:
<toolbar dock="none" id="toolbarMyCustom" name="My" custom&quot;=" withdraw="true" x="0"&lt;br"/>y="130">
<button id="Toolbar_Custom1" statustext="Custom1" status&quot;=" tiptext="Custom1" tip&quot;=" image="imageCustom1" command="MyCustom1Function1.acl"></button>
<separator/>
<button id="Toolbar_Custom2" statustext="Custom2" status&quot;=" tiptext="Custom2" tip&quot;=" image="imageCustom2" command="MyCustom1Function2.acl"></button>
</toolbar>
Here's the function I use to show/hide custom toolbars:
function show_hide_custom_toolbar(tb) {
# custom toolbar (tb) must be defined in APTCUSTOM/dialogs/editwindow.xml
# initial setting WITHDRAW=1
local x=dlgitem_get(current_window(),tb,'WITHDRAW');
if (x==1) {
dlgitem_set(current_window(),tb,'WITHDRAW','0');
dlgitem_set(current_window(),tb,'VISIBLE','1');
return;
local a=dlgitem_get(current_window(),tb,'VISIBLE');
if (a==0) {
}else if (a==1) {
dlgitem_set(current_window(),tb,'VISIBLE','0');
Lou Argyres
CEB.com
Oakland, CA
